Workflow Name | VPC domain is configured on Nexus switches using two workflows (in that order): 1. Create_PortChannel and 2. Create_VPC |
Description | First create Port-Channel across 2 Nexus Switches, this port-channel will be converted into peer-link in next workflow. In second workflow, configure VPC Domain ID and select Port-Channel as Peer-Link |
Prerequisites | Tested on UCSD 5.5 |
Category | Workflow |
Components | Nexus Switches |
User Inputs | LACP feature, VPC Feature, Port-Channel interfaces, VPC Domain ID, Nexus Management Interfaces |
Output | None |
- Download the attached .ZIP file below to your computer. *Remember the location of the saved file on your computer.
- Unzip the file on your computer. Should end up with a .WFD file.
- Log in to UCS Director as a user that has "system-admin" privileges.
- Navigate to "Policies-->Orchestration" and click on "Import".
- Click "Browse" and navigate to the location on your computer where the .WFDX file resides. Choose the .WFDX file and click "Open".
- Click "Upload" and then "OK" once the file upload is completed. Then click "Next".
- Click the "Select" button next to "Import Workflows". Click the "Check All" button to check all checkboxes and then the "Select" button.
- Click "Submit".
- A new folder should appear in "Policies-->Orchestration" that contains the imported workflow. You will now need to update the included tasks with information about the specific environment.
Create_PortChannel.wfdx.zip
