UCSD Add Disk to VM using Same Datastore
3796
Task NameAdd Disk to VM Same Datastore
Description
Prerequisites
Tested on 5.4
CategoryWorkflow
ComponentsvSphere 5.x
User InputsVM, DiskSizeGb
  8. Click "Submit".
Workflow Name:
Workflow:
Input Variables:
Importing with Custom Tasks:
VM in vCenter Before:
VM in vCenter After:
The workflow is missing from the doc.
Anuj
Workflow attached. Thanks Anuj!
Only supports VMs using a single datastore. Will update with improved version that uese "best" datastore VM currently connected to.
Content for Community-Ad
August's Community Spotlight Awards
