UCSD - Configure number of virtual sockets and number of cores per socket of a VM
3600
Task Name
Description
Prerequisites
  1. Tested on 5.4.0.2
CategoryWorkflow
ComponentsvSphere 5.x
User Inputse-mail address
Outpute-mail with counter
  5. Click "Browse" and navigate to the location on your computer where the .WFDX file resides. Choose the .WFDX file and click "Open".
  8. Click "Submit".
  9. A new folder should appear in "Policies-->Orchestration" that contains the imported workflow. You will now need to update the included tasks with information about the specific environment
A big thank you goes to:
Credit goes to Logesh Kandasamy and Tejeswar Sahu for developing the custom task
The import:
The workflow:
User input to the task:
     (VM Context could be set in global variable section and linked to the task input!)
The code:
importPackage(com.cloupia.model.cIM);//VMWareVMSummary,Account
importPackage(com.cloupia.service.cIM.inframgr);//InfraPersistenceUtil
importPackage(com.cloupia.lib.cIaaS.vmware);//VCenterConnectionManager
importPackage(com.vmware.vim25.mo);
importPackage(com.vmware.vim25);
importPackage(java.lang);
importPackage(java.util);
var vmId = input.vmid;
var noOfVirtualSockets = input.noOfVSockets;
var noOfCoresPerSocket = input.noOfCoresPerSocket;
var totalNoOfCores = noOfVirtualSockets*noOfCoresPerSocket;
logger.addInfo("vmId:"+vmId+",noOfVirtualSockets:"+noOfVirtualSockets+",noOfCoresPerSocket:"+noOfCoresPerSocket+",totalNoOfCores:"+totalNoOfCores);
//VMWareVMSummary getVMwareVMSummary(int vmId)
var vmwareVMSummary = InfraPersistenceUtil.getVMwareVMSummary(parseInt(vmId));
var accountName = vmwareVMSummary.getAccountName();
var vmName = vmwareVMSummary.getName();
logger.addInfo("Account name:"+accountName);
logger.addInfo("Vm name is:"+vmName);
//Account getAccount(String accountName)
var acc = InfraPersistenceUtil.getAccount(accountName);
try{
var si = new VCenterConnectionManager(acc).getServiceInstance();
}catch(e1){
logger.addError("Connection to the account "+accountName+" got failed."+e1);
ctxt.exit();
logger.addInfo("Service Instance is:"+si)
try {
var rootFolder = si.getRootFolder();
  var vm = new InventoryNavigator(rootFolder).searchManagedEntity("VirtualMachine",vmName);
  if (vm != null) {
  if(vm.getSummary().runtime.powerState.toString().equals("poweredOn")){
    logger.addError(" The vm "+vmName+" is powered on.The vm needs to be powered off first in order to change CPUs.....");
  ctxt.setFailed("The vm needs to be powered off first in order to change CPUs.....");
  ctxt.exit();
  //Thread.sleep(10000);
  while(true){
  var vmConfigSpec = new VirtualMachineConfigSpec();
     vmConfigSpec.setNumCoresPerSocket(parseInt(noOfCoresPerSocket));
     vmConfigSpec.setNumCPUs(parseInt(totalNoOfCores));
     var task = vm.reconfigVM_Task(vmConfigSpec);
  waitForTask = task.waitForTask();
  if("success"!=waitForTask){
  logger.addInfo("waiting for completion of the reconfiguration of the vm......");
    else{
    logger.addInfo("Reconfiguration of the vm got completed....");
    break;
  logger.addInfo("Task got completed successfully...");
     } catch (e) {
  logger.addError("Exception occured " + e);
  } finally {
  si.getServerConnection().logout();
gputtasw
Thanks, Orf for putting this on communities. Credit goes to Logesh Kandasamy and Tejeswar Sahu for developing the custom task.
Create
Recognize Your Peers
Content for Community-Ad
