UCSD Modify SCSI Controller in vCenter for a VM
1330
Task Name
Change the SCSI controller on a VM
Description
Prerequisites
  1. Tested on 5.4
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
VM ID
vCenter IP and ID and Password
Output
  5. Click "Browse" and navigate to the location on your computer where the .WFDX file resides. Choose the .WFDX file and click "Open".
  8. Click "Submit".
  9. A new folder should appear in "Policies-->Orchestration" that contains the imported workflow. You will now need to update the included tasks with information about the specific environment
Thank you for creating this a big Thank you goes out to:  Tejeswar Sahu
Workflow Execution:
The Code:
importPackage(java.net);
importPackage(java.lang);
importPackage(com.vmware.vim25);
importPackage(com.vmware.vim25.mo);
function modifySCSIController() {
  try{
  var si = new ServiceInstance(new URL("https://"+input.ipaddress+"/sdk"), input.username, input.password,true);
  logger.addInfo("input.ipaddress =" +input.ipaddress +", username ="+input.username+" , password ="+input.password)
  var rootFolder = si.getRootFolder();
  var vmid=input.vmname;
      logger.addInfo("VMID" + vmid);
     var api=ctxt.getAPI();
     var gvm=api.getVMBasicInfo(vmid);
     var vmwarename=gvm.getInstanceId();
  var vm = new InventoryNavigator(rootFolder).searchManagedEntity("VirtualMachine", vmwarename);
  if(vm==null)
  logger.addError("No VM " + vmwarename + " found");
  throw new Exception("NO VM found with specified name");
  logger.addInfo(" VM " + vmwarename + " found");
  var state = vm.getRuntime().powerState;
  logger.addInfo("vm Power state "+state.toString());
  var scsiSpec;
  var vmConfigSpec = new VirtualMachineConfigSpec();
  var scsi = findSCSIDevice(vm.getConfig());
  logger.addInfo("SCSI name is:"+scsi.getDeviceInfo().getSummary())
  if(scsi != null){
  if (state.toString().equals("poweredOn")){
  var powerofftask = vm.powerOffVM_Task();
  if(powerofftask.waitForMe()==Task.SUCCESS){
  logger.addInfo(vm + " powered off");
  logger.addInfo("Changing SCSI Controller Type:");
  scsiSpec = [modifySCSIConfigSpec(vm,  scsi)];
  logger.addInfo("Array length is:"+scsiSpec.length);
  }else{
  throw new Exception("No SCSI Controller found...");
  logger.addInfo("***Config Spec: "+scsiSpec);
  vmConfigSpec.setDeviceChange(scsiSpec);
  var task = vm.reconfigVM_Task(vmConfigSpec);
  var status =task.waitForTask();
  logger.addInfo("reconfig VM task status : "+ status);
  if(status == Task.SUCCESS) {
  if (state.toString().equals("poweredOff")){
  task = vm.powerOnVM_Task(null);
  if(task.waitForMe()==Task.SUCCESS)
  logger.addInfo(input.vmname + " powered on");
  }else{
  var info = task.getTaskInfo();
  logger.addError(info.getError().getFault());
  throw new Exception("Invalid configuration specification");
  logger.addInfo("Task successfull to change SCSI Controller type");
  si.getServerConnection().logout();
  }catch(e){
  logger.addError("Error: "+e);
  ctxt.setFailed("Task failed to change SCSI Controller type");
  ctxt.exit();
function modifySCSIConfigSpec(vm,  scsiCtrl)
  logger.addInfo("*********Modifying virtual device*******");
   var scsiSpec = new VirtualDeviceConfigSpec();
    scsiSpec.setOperation(VirtualDeviceConfigSpecOperation.edit);
    var scsiCtrl =  new VirtualLsiLogicSASController();
    scsiCtrl.setKey(1000);
    scsiCtrl.setBusNumber(0);
    scsiCtrl.setSharedBus(VirtualSCSISharing.noSharing);
    scsiCtrl.setUnitNumber(3);
    scsiSpec.setDevice(scsiCtrl);
    return scsiSpec;
function findSCSIDevice(vmConfig)
  var scsiController = null;
    var devices = vmConfig.getHardware().getDevice();
    for(var i=0;i<devices.length;i++)
  if(devices[i] instanceof VirtualSCSIController){
          logger.addInfo("scsi found at index:"+i);
  scsiController = devices[i];
  break;
    return scsiController;
Contributor
really thanks!
Contributor
Thanks for the info.
Beginner
Is the download gone? I am not seeing it.
Community Member
No download, plz fix it
Good thing I keep a backup copy.  Not sure how the code and the file disappeared.
Code and file are posted.
Orf Gelbrich
Check out UCS Director Workflow INDEX<https://communities.cisco.com/docs/DOC-56419> on Cisco Communities (External)
Community Member
Thank you, it's really helpful script
Content for Community-Ad
August's Community Spotlight Awards
