Orf Gelbrich
Task NamePower Shell Script example creating scripts with the @ symbol
Description
  1. Change the user of a running workflow
Prerequisites
  1. Tested on 5.3.1
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  1. userid to change to
Output
  8. Click "Submit".
A big thank you goes out to Joshua Barton for this inspiration:
How to create a power Shell script that spans multiple lines:
Example:
Several things to note here...
The start @' has one tick which means expressions in single quoted strings are not evaluated
The \$a and \$b need to be escaped in order for UCSD not to evaluate the varaible
The ${VMName} is replaced before the script is shipped off to the Power Shell agent
The workflow:
At run time the evaluation can be monitored
The workflow generates 3 files.
File #1 (b) is created:
File #1 (b) is then executed and produces 2 more files:
File #2
File #3
The workflow input:
Workflow user input:
The original inspiration:
