Orf Gelbrich
Task NamePre and Post VM Provisioning via API Call
Description
Prerequisites
  1. Tested on 5.3
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  8. Click "Submit".
Enable the Developer Menu (click on Admin):
Check the check box:
The API call in question:
The API call Options:
The workflow to import:
The workflow input (the VDC and Catalog needs to be updated and the user and e-mail address):
The questions upon executions:
The workflow:
The workflow Cloupia Script:
mportPackage(com.cloupia.model.cIM);
importPackage(java.util);
importPackage(java.lang);
importPackage(java.io);
importPackage(com.cloupia.lib.util);
importPackage(com.cloupia.model.cIM);
importPackage(com.cloupia.service.cIM.inframgr);
importPackage(org.apache.commons.httpclient);
importPackage(org.apache.commons.httpclient.cookie);
importPackage(org.apache.commons.httpclient.methods);
importPackage(org.apache.commons.httpclient.auth);
importPackage(com.cloupia.model.cEvent.notify);
importPackage(com.cloupia.lib.util.mail);
importPackage(com.cloupia.fw.objstore);
importPackage(com.cloupia.lib.util.managedreports);
// User input section
var vmName = ctxt.getInput("VM_Name");
var vmComment = ctxt.getInput("VM_Comment");
var vmCPU = ctxt.getInput("VM_CPU");
var vmMemory = ctxt.getInput("VM_Memory");
var catId = ctxt.getInput("VM_Catalog");
var vdcId = ctxt.getInput("VM_VDC");
var vmUser = ctxt.getInput("VM_USER");
var vmInputA1 = ctxt.getInput("VM_Post_Provisioning_Input_A1");
var vmInputA2 = ctxt.getInput("VM_Post_Provisioning_Input_A2");
//write everything to the SR log
logger.addInfo("vmName = "+vmName);
logger.addInfo("vmComment = "+vmComment);
logger.addInfo("vmMemory = "+vmMemory);
logger.addInfo("catId = "+catId);
logger.addInfo("vdcId = "+vdcId);
logger.addInfo("vmUser = "+vmUser);
//Convert the VDC and Catalog ID to a Name
var vdc = VDCUtil.getVDC(vdcId);
var vdcName = vdc.getVdcName();
var cat = VDCUtil.getVDCCatalogItem(catId);
var catName = cat.getCatalogItemName();
logger.addInfo("CatalogName: " + catName);
logger.addInfo("vdcName: " + vdcName);
// Set up the API call to provision a VM
var params = new APIProvisionParams();
params.setCatalogName(catName);
params.setVdcName(vdcName);
params.setUserID(vmUser);
params.setVmName(vmName);
params.setComments(vmComment);
params.setCores(vmMemory);
params.setMemoryMB(vmMemory);
//If Post Provision workflow has user inputs then the following code is required to pass user inputs to API.
//If the post provision workflow has only task inputs then skip the below code. It is not required to setPostProvWFUserInputs.
var nv1 = new APINameValue("A1",vmInputA1);
var nv2 = new APINameValue("A2",vmInputA2);
var list = new APINameValueList();
list.addNameValue(nv1);
list.addNameValue(nv2);
//Add this inputs list to provision params.
params.setPostProvWFUserInputs(list);
var childSrId = ctxt.getAPI().userAPIProvisionRequest(params);
var status = ctxt.waitForCompletion(childSrId, 1800000);
if (status == 0)
     logger.addInfo("Provisioned SR ID  ="+ childSrId+ " successfully.");
} else {
     logger.addError("SR ID  ="+ childSrId+ " failed");
The Catalog in question:
The catalog details:
The post provisioning workflow:
The details of the post provisioning workflows:
This workflow has 2 inputs:
The workflow:
The inputs:
psivakum
In the "Set up the API call to provision a VM" section, please change the following in the script.
params.setCores(vmMemory); should be changed to params.setCores(vmCPU);
Note: In the existing script, memory input is getting passed as CPU input. hence, requesting to make the required changes after inporting the WF
Orf Gelbrich
You should use this one…
https://communities.cisco.com/docs/DOC-63923
psivakum
Thanks Orf.
