UCSD - Type Conversion - dvPortGroup to Generic PortGroup
895
Prerequisites
  1. Built on UCSD 5.3
  8. Click "Submit".
Occasionally in UCS Director you will find yourself in a case where a task requires an input of one type, but the data came from another task in a different "type".  Sometimes this isn't a big deal as the data is correct, it's just a type problem.  Other times, the information you need is in the data, but the actual format is incorrect.  This custom task is for one of these cases.
In UCS Director, there are several "types" that relate to VMware Port-Groups from vCenter.  There are types for dvPortGroups, stdPortGroups, and a Generic Port Group.  Each of these represent the data slightly different, which means you can't just interchange them.  I recently ran into a case when working with ACI automation where the Task to Add vCenter to an EPG has an output of the dvPortGroup, but I needed that information as a Generic PortGroup to create a new VDC based on the ACI structure.  To resolve this, I built this custom task which decodes and converts the data to the right format.
The attachment includes a sample workflow using the task, and the task itself.
Create
Recognize Your Peers
Content for Community-Ad
