Orf Gelbrich
Task NameOpenstack Integration with UCSD
Description
Prerequisites
  1. Tested on 5.3
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  8. Click "Submit".
Credits go to Jose Moreno and Russ Whitear.
The workflows on import into UCSD:
The workflow loacation:
The workflow:
PDF / PDF workflow conversion thanks to Simon Price (also attached):
Hi Orf Gelbrich,
We are doing POC for Openstack Integration with UCS Director. We are using UCSD 5.3 & Openstack ver 14 (Newton) installed on CentOS 7.
I imported the workflow and modified the values according my environment. While it reaching creating Openstack Network stage it throws an error.
Nov 22, 2016 18:47:28 SGT Return code 201: successfully configured Openstack task.
Nov 22, 2016 18:47:28 SGT Response received: {'network': {'provider:physical_network': null, 'updated_at': '2016-11-22T10:47:27Z', 'revision_number': 2, 'mtu': 1450, 'id': 'c9dad07a-982a-4797-a4c9-1c376c00eec8', 'router:external': false, 'availability_zone_hints': [], 'availability_zones': [], 'ipv4_address_scope': null, 'shared': false, 'project_id': '4273c18b25db4059be78191339b5295b', 'status': 'ACTIVE', 'subnets': [], 'description': '', 'tags': [], 'ipv6_address_scope': null, 'provider:segmentation_id': 82, 'name': '$Name-NW1', 'admin_state_up': true, 'tenant_id': '4273c18b25db4059be78191339b5295b', 'created_at': '2016-11-22T10:47:27Z', 'provider:network_type': 'vxlan'}}
Nov 22, 2016 18:47:28 SGT VLAN ID found: 82, Network ID c9dad07a-982a-4797-a4c9-1c376c00eec8
Nov 22, 2016 18:47:28 SGT Invliad inner task name: custom_openstack_delete_network
Nov 22, 2016 18:47:28 SGT Error occured at line # 50
Nov 22, 2016 18:47:28 SGT [Line#50] var undoContext = ctxt.createInnerTaskContext(undoHandler);
Nov 22, 2016 18:47:28 SGT Task: Openstack - chained tasks (custom_openstack_create_nw_nologin) failed with error - sun.org.mozilla.javascript.internal.WrappedException: Wrapped java.lang.Exception: [InnerTaskExecution] Invliad inner task name: custom_openstack_delete_network (<Unknown source>#50) in <Unknown source> at line number 50, selectedContext=<None>
Nov 22, 2016 18:47:28 SGT Task #7 (Openstack - chained tasks (custom_openstack_create_nw_nologin)) failed after 0 seconds
Nov 22, 2016 18:47:28 SGT Input/Output values for Task #7 (Openstack - chained tasks (custom_openstack_create_nw_nologin)):
Nov 22, 2016 18:47:28 SGT [Local Input: Network Name = $Name-NW1]
Nov 22, 2016 18:47:28 SGT [Mapped Input: Openstack Controller IP = 192.168.1.205]
Nov 22, 2016 18:47:28 SGT [Mapped Input: token = 7b96e3d5dddc4b3cb7e44fbe97cd61bc]
Nov 22, 2016 18:47:28 SGT Completed workflow item number 8, with status Failed
Need your help in resolve the same. Thanks in Advance!!
Manibalan M
Orf Gelbrich
This does not look right…
The $Name did not resolve.
Orf Gelbrich
Check out UCS Director Workflow INDEX<https://communities.cisco.com/docs/DOC-56419> on Cisco Communities Site (Twitter @UCSDGURU)
I newly imported the workflow and modified the Openstack details still the same..
Nov 22, 2016 20:46:28 SGT Executing custom action Openstack - chained tasks (custom_openstack_create_nw_nologin)
Nov 22, 2016 20:46:28 SGT Executing custom script for openstack_create_nw_nologin
Nov 22, 2016 20:46:28 SGT Request to http://192.168.1.205:9696/v2.0/networks
Nov 22, 2016 20:46:28 SGT Sending payload: {'network': {'name': '$Name-network-01','admin_state_up': true}}
Nov 22, 2016 20:46:28 SGT Response received: {'network': {'provider:physical_network': null, 'updated_at': '2016-11-22T12:46:27Z', 'revision_number': 2, 'mtu': 1450, 'id': '32edc209-0466-4fdb-b41d-cdf43946b75d', 'router:external': false, 'availability_zone_hints': [], 'availability_zones': [], 'ipv4_address_scope': null, 'shared': false, 'project_id': '7a5f5e1012d64a2e84c81fbcc33fd5f0', 'status': 'ACTIVE', 'subnets': [], 'description': '', 'tags': [], 'ipv6_address_scope': null, 'provider:segmentation_id': 28, 'name': '$Name-network-01', 'admin_state_up': true, 'tenant_id': '7a5f5e1012d64a2e84c81fbcc33fd5f0', 'created_at': '2016-11-22T12:46:27Z', 'provider:network_type': 'vxlan'}}
Nov 22, 2016 20:46:28 SGT Return code 201: successfully configured Openstack task.
Nov 22, 2016 20:46:28 SGT VLAN ID found: 28, Network ID 32edc209-0466-4fdb-b41d-cdf43946b75d
Nov 22, 2016 20:46:28 SGT Invliad inner task name: custom_openstack_delete_network
Nov 22, 2016 20:46:28 SGT Error occured at line # 50
Nov 22, 2016 20:46:28 SGT [Line#50] var undoContext = ctxt.createInnerTaskContext(undoHandler);
Nov 22, 2016 20:46:28 SGT Task: Openstack - chained tasks (custom_openstack_create_nw_nologin) failed with error - sun.org.mozilla.javascript.internal.WrappedException: Wrapped java.lang.Exception: [InnerTaskExecution] Invliad inner task name: custom_openstack_delete_network (<Unknown source>#50) in <Unknown source> at line number 50, selectedContext=<None>
Nov 22, 2016 20:46:28 SGT Task #7 (Openstack - chained tasks (custom_openstack_create_nw_nologin)) failed after 0 seconds
Nov 22, 2016 20:46:28 SGT Input/Output values for Task #7 (Openstack - chained tasks (custom_openstack_create_nw_nologin)):
Nov 22, 2016 20:46:28 SGT [Local Input: Network Name = $Name-network-01]
Nov 22, 2016 20:46:28 SGT [Mapped Input: Openstack Controller IP = 192.168.1.205]
Nov 22, 2016 20:46:28 SGT [Mapped Input: token = 40fe290411d7493eaf4eecaafaa37a49]
Nov 22, 2016 20:46:28 SGT Completed workflow item number 8, with status Failed
Can I know what ver of Openstack it was tested before.
Thanks..
Orf Gelbrich
The network name “'$Name-network-01'” does not look right. $ABC are variables usually in UCSD and it looks like your variable $Name is not resolving or is getting no input.
Orf Gelbrich
Okay, but the name was there already in the workflow, I didn't change anything in the network part. Can you suggest me any alternate to resolve the issue.
Thanks..
Orf Gelbrich
Where is $Name coming from. Is it in a field in a task? Is it in a Global var? Is it user input? Which task? Picture?
Orf Gelbrich
Its in the 7th Task (custom_openstack_create_nw_test), Create OpenStack Network --> Task Inputs.
I am not able to add image here.
Thanks.
Orf Gelbrich
Here is my e-mail
ogelbric@cisco.com
Orf Gelbrich
