Alejandro Madurga Ainoza
Task NameCIDR Calculator
Description
  1. Gets the CIDR number from a subnet mask, pretty usefull to avoid to input both when some tasks
    needs the subnet mask and other the CIDR.
Prerequisites
  1. Tested on 5.1
CategoryWorkflow
Components
User Inputs
  1. Subnet Mask
  8. Click "Submit".
  9. A new folder should appear in "Policies-->Orchestration-->Tools" that contains the imported workflow. You will now need to update the included tasks with information about the specific environment.
This is a custom task:
And after the import it can be found under the custom task section:
chao guo
I following the guide to import the workflow into the UCSD in local, But I can not find the workflow i imported.
Orf Gelbrich
I added 2 more screen shots for the location of this custom task on the UCSD appliance.
Orf Gelbrich
I added 2 more screen shots to illustrate where the custom task is located on UCSD.
Orf Gelbrich
Check out UCS Director Workflow INDEX<https://communities.cisco.com/docs/DOC-56419> on Cisco Communities (External)
