Orf Gelbrich
Task NameThe UCSD Custom Task Script Bundle
Description
  1. Change the user of a running workflow
Prerequisites
  1. Tested on 5.3.1
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  1. userid to change to
Output
  8. Click "Submit".
This can also be found on www.cisco.com under the UCS Director download section.
Here are the 126 Tasks in this bundle:
APIC TenantAvailability.wfdx
Add DRS Rules.wfdx
Add PortGroup.wfdx
Add SR Comments Itself.wfdx
Add VLAN To Group.wfdx
Add VLAN To SP vNIC.wfdx
Add VMKernel to DVSwitch.wfdx
Add Virtual Disk.wfdx
AddMSPgroup.wfdx
AddVMtoGroup.wfdx
Assign Image To Group .wfdx
AssignCatalogToGroup.wfdx
AssignVLANToGroup.wfdx
AssignVMstoVDC.wfdx
Bind SP To Template.wfdx
BulkImportsAccounts.wfdx
Calling XML Based GET Api.wfdx
Change VSAN Association.wfdx
ChangeUser.wfdx
CloudUtilizationMonitor.wfdx
Create Custom Lov.wfdx
Create Datacenter.wfdx
Create Free Vlan Lov.wfdx
Create NetAppAccount.wfdx
CreateACLRule.wfdx
CreateNetworkPolicy.wfdx
CreateServiceProfileTemplate.wfdx
CreateStoragePolicy.wfdx
CreateVMComputePolicy.wfdx
CreateVMDiskClone.wfdx
CreateVMNetworkPolicy.wfdx
CreateVMStoragePolicy.wfdx
CreateVMSystemPolicy.wfdx
DRS VM GroupManager Actions.wfdx
DRSHost GroupManager Actions.wfdx
Delete All Service Request.wfdx
Delete DRS Rule Task.wfdx
Delete VLAN From Group.wfdx
Delete VLAN ID From SP vNIC.wfdx
DeleteACLCustom.wfdx
DeleteAllVMsFromGroup.wfdx
DeleteServiceDeliveryPolicy.wfdx
Device Alias Report.wfdx
DisjointNetwork.wfdx
DynamicLovs.wfdx
EMC Map LUNs.wfdx
Enable VMRC.wfdx
Example Custom Tasks.wfdx
Execute Powershell.wfdx
Execute VIXScript.wfdx
ExecuteMysqlQuery.wfdx
FilewriteSample.wfdx
FilterLOV.wfdx
FolderDelete.wfdx
FreeVlanIdFromPool.wfdx
GenerateNumber.wfdx
Get VMs by UserID.wfdx
Get WWN.wfdx
GetAllVmdetailsInArray.wfdx
GetDatastroeNameFromVMName.wfdx
GetGroupAdmin.wfdx
GetHyperVMSnapshot.wfdx
GetInputValueBySRID.wfdx
GetUUID.wfdx
GetVolumeSize.wfdx
HyperV VM Sanpshot Details.wfdx
License Utilization Report.wfdx
LoginProfile.wfdx
Map LUN as RDM.wfdx
Map LUN to Initiator Group.wfdx
Map LUN to VNX Storage Groups.wfdx
Modify Credential.wfdx
Modify Quota.wfdx
Modify Vmware Deployment Policy.wfdx
ModifyOrgPermission.wfdx
ModifyServiceProfile.wfdx
ModifyVMLabel.wfdx
MonthlyBilling.wfdx
MonthlyReport CSV.wfdx
MountISO.wfdx
Multiple VM and Multiple Templates.wfdx
Multitask.wfdx
NetAppIdentity.wfdx
Nimble volume to ESXi Host.wfdx
Ping test.wfdx
Provision VM with wait time.wfdx
ProvisionVM.wfdx
ReadFromXML.wfdx
Register Blade Server LOV.wfdx
RegisterMultiSelect.wfdx
RegisterTabularLOV.wfdx
RemoveESXiCluster.wfdx
RemoveSanZone.wfdx
Rename vCenter Folder Name.wfdx
Reset Password Workflow.wfdx
ResizeVMDisk.wfdx
Retrieve Content.wfdx
Rollback Generate Number.wfdx
SFTPFileUpload.wfdx
SSHPowerShellAndRESTAPIAccess.wfdx
Select UCS ServiceProfile.wfdx
ServerPool.wfdx
ServiceContainer Task.wfdx
StaticIPPoolPolicy.wfdx
TaskOutputFieldList.wfdx
TaskStatusMessage.wfdx
TenantPolicy.wfdx
TenantVDC.wfdx
TestAccountConnectivity.wfdx
TriggerNetAppInventory.wfdx
Unbind SP From Tenmplate.wfdx
Update Custom Lov.wfdx
VHBA Template.wfdx
VM Annotation.wfdx
VM Disk Resize.wfdx
VM Naming.wfdx
VMFS Datastore.wfdx
VMID From SR Workflow.wfdx
VMResourceAllocation .wfdx
VMSelector.wfdx
VMWare VM Inventory Collector.wfdx
WWNNWWPNPool.wfdx
Workflow Rollback.wfdx
forloopsample.wfdx
policynameToIpPoolPolicyselectorConverter.wfdx
vNIC Template.wfdx
Orf Gelbrich
How do we get this
To show up for all the other postings?
Orf Gelbrich
Check out UCS Director Workflow INDEX<https://communities.cisco.com/docs/DOC-56419> on Cisco Communities Site (Twitter @UCSDGURU)
