Orf Gelbrich
Task Name
Workflow Rules
Description
Workflow input rules example
Prerequisites
Validated on UCSD 6.6
Category
Workflow Task
Components
User Inputs
  1. Number of disks
Output
Result of operation
Installation
  2. Unzip the file on your computer. Should end up with a .WFDX file.
  8. Click "Submit".
The workflow:
Workflow input:
Screen Shot 2018-07-25 at 10.56.42 AM.pngScreen Shot 2018-07-25 at 10.56.35 AM.pngScreen Shot 2018-07-25 at 10.56.27 AM.png
Workflow run with one disk:
Screen Shot 2018-07-25 at 11.01.11 AM.pngScreen Shot 2018-07-25 at 11.01.44 AM.pngWorkflow run with 2 disks:
Screen Shot 2018-07-25 at 11.03.51 AM.pngScreen Shot 2018-07-25 at 11.04.35 AM.pngWorkflow run with 3 disks:
Screen Shot 2018-07-25 at 11.06.42 AM.pngScreen Shot 2018-07-25 at 11.06.55 AM.png
dkhwch
Has anyone also experienced problems when using Custom Workflow Inputs for me (regex validated gen_text_input) and User Input Rules together ? Today I've used a such a Custom Workflow Input as an Input Type for one of my User Inputs in a Workflow. In that same Workflow i was also using User Input Rules. When testing the workflow, I noticed that my validated input was not working. So I tried it in a different workflow, where i had nothing configured, but this one validated Input and there the validation worked correct. After doing that, i tried the validated user input again in the original workflow but this time with User Input Rules turned off and that way the validation worked. But after enabling the User Input Rules again, the validation didn't work anymore. Am I missing a setting, that i have to do when using these settings together ?
nakesarl
May we know the UCSD version 6.6 or 6.7?
dkhwch
Yes of course my bad for not mentioning that in my first post.. Im using UCSD version 6.6
