8945 Headset hookswitch
Steve Boyd
Question about the 8945 headset and wireless hookswitch capability.   Trying to see which headsets work with the 8945 for this capability and the admin guide has a link to supported models, but the link is broken.  Anyone have an updated link?
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/8941_8945/8_5/english/admin_guide/6921set.html#wp1031158
5 Replies 5
skilambi
See here for options from Jabra
http://www.jabra.com/pv_obj_cache/pv_obj_id_48730961DBC2AC0190F9B0BAFF940A088E8C4A00/filename/PM_BR_EHSGUIDE_1201_V09.pdf
I am sure Plantronics has similar ones
Also as you might know you can also do bluetooth natively with these models
Srini
Thank you, Srini, for your helpful response.
stboyd, can you try accessing the link again, please? I was able to access the link without any problems. If you are still having trouble, let me know, and I can look into finding a solution.
Kelli Glass
Moderator for the Cisco Collaboration Community
dalewalk
stboyd,
Be careful with headsets and 894x series phones.  With bluetooth you can answer, hold, and hang up calls from the headset.  If you move to Plantronics many of their headsets are DECT between the base unit and the headset.  The range is very good but you will need a lifter to answer calls without touching the phone.  Do not be fooled by the "electronic hookswitch cable" plantronics offers.  It only works in 7900 series phones with an AUX jack.  Feel free to unicast me if you want to discuss.  I am in the process of implementing about 2000 89xx and 99xx sets in a K-12 customer.
hello:
i require a handset with the RJ9 coneector
this is used in a classified environment, thus no bluetooth
i might also want an option for a "push to talk"
any recommendations?
ritesh.tandon
Hi Stephen,
Pls see attached Jabra link which describes compatibility of Cisco IP phone portfolio (including 8945) and Electronic Hook Switch Options
http://www.jabra.com/~/media/Documentation/Strategic%20Alliances/Cisco/Cisco%20Compatibility%20Guides/Compatibility_Brochure_Jabra_Cisco_NA_V07.pdf
Look into page # 3 with wireless option
Jabra headsets are Cisco IVT certified and fully tested by Jabra. Feel free to reach out in case of any questions or you need any help
Thank you
