ATA 186 Support for CUCM 9.X
gpsriramdc
Level 4
Level 4
Hi All,
As per the Upgrade Rediness assessment tool ATA 186 has not be validated for CUCM 9.X. Has anyone tested ATA 186 with CUCM 9.X ?
We have 10 ATA 186 in Cluster . We unable to proceed for the upgrade with out this confirmation. Help on this.
Thanks in Advance..
keglass
Level 7
Level 7
Sriram,
Thank you for posting to the Collaboration Community. I think you will find the information you are looking for in the Cisco Support Community where a similar question was posted.
https://supportforums.cisco.com/message/3908954#3908954
Hope that helps,
Kelli Glass
Moderator for the Cisco Collaboration Community
Hi Kelli,
Thanks for the clarifications..
Do youknow if ATA 186 is supported also for CUCM 10.0 ?
The word support for a product that is EOL is based on the EOL bulletin
It will work but if the support date has passed then if you have issues there is no TAC support
Srini
