auto attendant on ccme
tkavithas87
Beginner
Beginner
i have configured auto attendand on ccme.here when someone calls to auto attendant number at office hours receptionist phone number should ring,after office hours it should go to auto attendant .but in my configuration both office hours and after office hours it directly  goes to auto attendant.does any one know how  to configure this?
thanks
6 Replies 6
Karthik Sivaram
Enthusiast
Enthusiast
hi Kavitha,
Do you have the show version , show run?
Karthik
cme#show version
Cisco IOS Software, C1861 Software (C1861-ADVENTERPRISEK9-M), Version 15.2(3)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Fri 23-Mar-12 15:23 by prod_rel_team
ROM: System Bootstrap, Version 12.4(11r)XW3, RELEASE SOFTWARE (fc1)
cme uptime is 6 days, 10 hours, 27 minutes
System returned to ROM by reload at 13:05:42 pssss Wed Aug 8 2012
System restarted at 13:07:28 pssss Wed Aug 8 2012
System image file is "flash:c1861-adventerprisek9-mz.152-3.T.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
Tis product contains cryptographic features and is subject to United
Imorters, exporters, distributors and users are responsible for
comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco C1861E-UC-4FXO-K9 (MPC8358) processor (revision 0x300) with 497664K/26624K bytes of memory.
Processor board ID FGL161221C8
MPC8358 CPU Rev: Part Number 0x804A, Revision ID 0x21
12 User Licenses
10 FastEthernet interfaces
2 terminal lines
1 Virtual Private Network (VPN) Module
4 Voice FXO interfaces
4 Voice FXS interfaces
1 Voice MoH interface
1 cisco service engine(s)
128K bytes of non-volatile configuration memory.
126976K bytes of ATA CompactFlash (Read/Write)
cme#show run
voice-port 0/1/2
connection plar opx 2040
interface Integrated-Service-Engine0/0
ip address 192.168.104.253 255.255.255.0
service-module ip address 192.168.104.252 255.255.255.0
service-module ip default-gateway 192.168.104.253
dial-peer voice 4 voip
destination-pattern 2...
session protocol sipv2
session target ipv4:192.168.104.252
dtmf-relay rtp-nte
codec g711ulaw
se-192-168-104-252#show run
ccn trigger sip phonenumber 2040
application "autoattendant"
enabled
maxsessions 5
end trigger
ccn application autoattendant aa
description "cisco auto-attendant"
enabled
maxsessions 5
script "aa.aef"
parameter "dialByExtnAnytime" "false"
parameter "busOpenPrompt" "AABusinessOpen.wav"
parameter "dialByExtnAnytimeInputLength" "4"
parameter "operExtn" "9521"
parameter "welcomePrompt" "AAWelcome.wav"
parameter "disconnectAfterMenu" "false"
parameter "dialByFirstName" "false"
parameter "busClosedPrompt" "AABusinessClosed.wav"
parameter "allowExternalTransfers" "true"
parameter "holidayPrompt" "AAHolidayPrompt.wav"
parameter "businessSchedule" "systemschedule"
parameter "MaxRetry" "3"
end application
Hi Kavithas,
Can you please share the auto attendant script?
I think script is not directing the number properly to receptionist's number.
In Office hours it should redirect and in after office hours it should go to auto attendant.
Please check the script if it doesn't work properly then please modify accordingly.
Nikhil Joshi.
There is no time of day routing in CCME, so you will need to build a schedule in CUE and build the logic in the AA script to route to proper destination.
Chris
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
To support Business hours and Holiday schedule on B-ACD/AA with the need to configure CUE, you can use my modfied script available at the website mentioned in my profile.
hi paolo,
in which website?i couldnt find the website.pls share the website
thanks
kavi
Recognize Your Peers
