08-12-2011 11:51 AM - edited 03-19-2019 03:25 AM
Hi everyone,
I would apreciate any kind of help on this. We have a DID coming on a PRI pointing to a B-ACD queue. Then, it's stopped working, because it felt like it, and now just hangs up even before playing the "transfer to basic-ACD prompt".
The configuraiton looks fine, I replaced all prompts and .tcl scripts with fresh ones dowloaded from cisco with no success. when I debug voip application script, nothing is trigered as if the script is never reached. Other debugs show me that the adequate dial-peer is beeing reached, but show call application sessions displays nothing. I tried Call application voice load ...... and it seems to load the .tcl script,,but nothing works. I bypassed the script with the same config, and sent directly to A1010 on the voice translation rule 14, I could then reach the hunt group without anyproblem,,,,,pointing the finger at the aaservice0.
System was rebooted, I removed all and re-installed the B-ACD with CCA (like at first install), no luck.
Any ideas???? I am running out of steam about now.
application
service aaservice0 flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl
param aa-pilot 1010
paramspace english index 0
param drop-through-prompt _bacd_allagentsbusy.au
param second-greeting-time 60
paramspace english language en
param call-retry-timer 15
param voice-mail 7000
param max-time-call-retry 600
param service-name bacd
param number-of-hunt-grps 1
paramspace english location flash:/bacdprompts/
param drop-through-option 1
param handoff-string aaservice0
param max-time-vm-retry 1
service bacd flash:/bacdprompts/app-b-acd-3.0.0.2.tcl
param number-of-hunt-grps 10
param queue-len 30
param queue-cme-debugs 1
param aa-hunt1 A1010
tftp-server flash:/bacdprompts/app-b-acd-3.0.0.2.tcl alias app-b-acd-3.0.0.2.tcl
tftp-server flash:/bacdprompts/app-b-acd-aa-3.0.0.2.tcl alias app-b-acd-aa-3.0.0.2.tcl
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
dial-peer voice 3009 pots
description billeterietest-B_ACD
translation-profile incoming billeterietest-B_ACD_Called_14
incoming called-number 514XXXXXXX
direct-inward-dial
port 0/3/0:23
voice translation-rule 14
rule 1 /514XXXXXXX/ /1010/
voice translation-profile billeterietest-B_ACD_Called_14
translate called 14
08-12-2011 11:53 AM
Obvious typo in the title, it's a UC560.
