12-14-2010 04:38 AM - edited 03-19-2019 02:04 AM
I have two server cisco unity connection version 7, and I have 2 site the first site is branch site and the second site is backup site.
I want to install the first server (primary server) in the site branch and the second server (secondary server) in site backup.
How much bandwith requiered to work cisco unity connection normaly.
NB: I have 24 ports.
thanks a lot,
best regards,
Omar YUNSI
Solved! Go to Solution.
12-14-2010 05:41 AM
Hi Omar
In Unity Connection 7.0, Active/Passive feature is not there.
I am not sure if there is anyway to reducethe bw. This is tested by the Development Team and hence recommended.
There is a drastic decrease in the requirement in version 8.0.
Depending on the number of voice messaging ports on each Connection server, the path of connectivity must have the following guaranteed bandwidth with no steady-state congestion:
–For 50 voice messaging ports on each server—7 Mbps
–For 100 voice messaging ports on each server—14 Mbps
–For 150 voice messaging ports on each server—21 Mbps
–For 200 voice messaging ports on each server—28 Mbps
–For 250 voice messaging ports on each server—35 Mbps
Not sure if it is feasible for you to move to 8 or 8.5.
Hope it helps.
Regards..
Mahesh Dawar
12-14-2010 04:49 AM
Hi Omar
Here are the requirements:
–For 48 voice messaging ports on each server—50 Mbps
–For 96 voice messaging ports on each server—100 Mbps
–For 144 voice messaging ports on each server—150 Mbps
•The maximum round-trip latency must be no more than 20 ms.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/requirements/7xcucsysreqs.html#wp151620
Hope it helps.
Mahesh Dawar
12-14-2010 05:15 AM
Hi Mahesh,
thanks too much for your answer,
the document that you sent me help me.
But the bandwith requiered is too large. Can I install cisco unity in actif/passif?? do you have any idea to minimize the bandwith value?
thanks a lot,
Best Regards,
Omar YUNSI
12-14-2010 05:41 AM
Hi Omar
Hope it helps.
Regards..
Mahesh Dawar
12-14-2010 06:29 AM
Thanks too much Mahesh for your help
