BARS utility, protocol and port used
kimlong
I have the BARS admin guide, document version 4.0(12)and after looking through it and searching through the forum posts,
I'm not able to locate much about the BARS utility ports/protocols. Anyone out here have this info?
Kim
bwilmoth
Level 5
Level 5
The BARS utility does a simple file extracion from the server plus accessing the database on the server. So as that is the case then the ports that you would need to open to allow the back up occur are TCP 445 for SMB (Windows file sharing) and TCP 1433 for MS SQL
Sorry for the delay. Thank you so much.
