BAT - Cisco Dual Mode for iPhone
Shaijala
Is there any way to bulk add Cisco Dual Mode for iPhone using bat. I just tried with normal bat template but getting
d�*�����c��ߋ i9��wp� is not a supported field error
CUCM  version - 8.5
Sam
Shaijala
Hello
There was some issue with the CSV file, created a new file and that worked properly.
Attached the bat file.
Thank you very much for adding the file to your post! you have saved me quite a bit of time!
