BE6K-UCL-ENH - PAK or not?
mmreid001
ive recently purchased BE6K-UCL-ENH to add some further user to my BE6000 which did come with a starter bundle. The licenses do not seem to have come with any PAK or file to download. Are these honor based licenses and if so how do i apply these to the server or do i not need to?
skilambi
Mark
It is not honor based for sure, UCL ENH is enforced in PLM. If you pull up the order you should see a PAK but if you don't open a case with licensing, provide the Cisco SO and go from there
5 Replies 5
skilambi
Mark
Thanks. I was under the impression this was only a RTU license though. RTU don't have PAKs
Now I'm confused
This one isn't RTU, it's the actual Ucl Enh
Srini
HHow do you explain this. See attached. Have I purchased The wrong license? It even says right to use notificationIMG_3343.PNG
Did you purchase just one license? In any event open a case with licensing and provide that SO number to look up PAK.
if your intent was to order one ENH to add a phone or jabber soft phone as an example that's the right license yiu need to apply to plm
