12-21-2012 03:18 AM - last edited on 03-25-2019 09:48 PM by ciscomoderator
hi,
i have installed CAD 8.0(1a) and i am trying to configuere recording and statistc Replication.
wehen i try to set it up through postinstall,it gives me below error:
Recrding and statistics replication failed,
Error: encountered en error when addidng the publisher.
i went through logs and found below:
egin sp_splk_drop_publisher
end sp_splk_drop_publisher
Msg 50000, Level 16, State 1, Server HPLAB6\CADSQL, Procedure craLogMessage, Line 210
(58) ERR craDropPublication :The publication(cra_agent_pub) is not a
valid CRA publication
(58) ERR craDropSubscription :The publication(cra_agent_pub) is not a
Msg 21147, Level 16, State 1, Server HPLAB6\CADSQL, Procedure sp_MSCheckmergereplication, Line 12
The 'FCRasSvr' database is not published for merge replication.
(58) ERR craDropPublication :Call to sp_dropmergepublication failed
(0 rows affected)
End sp_splk_drop_publishe
futher more when i checked SQL server logs i found below.
Error: 450000, Severity: 16, State: 1.
2012-12-21 15:43:46.37 spid58 (58) ERR craDropPublication :The publication(cra_agent_pub) is not a valid CRA publication
2012-12-21 15:43:46.37 spid58 Error: 50000, Severity: 16, State: 1.
2012-12-21 15:43:46.55 spid58 Error: 450000, Severity: 16, State: 1.
2012-12-21 15:43:46.55 spid58 (58) ERR craDropSubscription :The publication(cra_agent_pub) is not a valid CRA publication
2012-12-21 15:43:46.55 spid58 Error: 50000, Severity: 16, State: 1.
2012-12-21 15:43:46.60 spid58 Error: 450000, Severity: 16, State: 1.
2012-12-21 15:43:46.60 spid58 (58) ERR craDropPublication :Call to sp_dropmergepublication failed
2012-12-21 15:43:46.60 spid58 Error: 50000, Severity: 16, State: 1.
2012-12-21 15:43:47.82 spid58 Error: 450000, Severity: 16, State: 1.
2012-12-21 15:43:47.82 spid58 (58) ERR craAddPublication :The publication(cra_agent_pub) is not a valid CRA publication
2012-12-21 15:43:47.82 spid58 Error: 50000, Severity: 16, State: 1.
i am stuck at this perticular point and i need some help to get Rid of this errors
help will be highly appreciable
regards,
Chintan
02-27-2013 02:18 AM
Hi i faced with this problem too. Have you resolve this issue?
02-27-2013 10:16 AM
Hi Chintan,
Please see if the below post helps you here.
https://supportforums.cisco.com/thread/272613
Anand
02-27-2013 10:40 PM
Hi Anchoudh,
Thanks for answer,.i saw that post earlier and try to remake replication it doesn't help.
when i try to enable db replication the following error pop-up:
Cisco Agent Desktop Configuration Setup
Recording and Statistics replication failed.
Error: encountered an error when adding the local distributer
(51) ERR craAddLocalDistributor :Failed to find the distribution DB using craGetDistributionDB
(51) ERR craDropPublication :Call to sp_dropmergepublication failed
(51) ERR craDropSubscription :The publication(cra_agent_pub) is not a valid CRA publication
(51) ERR craDropPublication :The publication(cra_agent_pub) is not a valid CRA publication
FCRasSvr database exists and does not need upgrading.
02-28-2013 01:10 AM
i tried withh almost all the stuff,i manually tried to setup one servers as publisher and other as subrscriber but it also didnt help.
then i left setting up CAD server, as i dont have DEmo licences also.
if any body found any sollution please share.
04-18-2013 01:27 AM
HI all,
This is FYI,
this issue is resolved by moving to CAD 8.5.4
we might be hitting some bug here(dont know exactly which one)
and the same bug is resolved in 8.5 release and the same worked for me aslo.
regards
Chintan Gajjar
