Call Manager 4.2.3(sr1) with 7970 url too long
ezy
Beginner
Beginner
I have a problem with a 7970 phone registered to a CCM 4.2.(3)sr1. When I try to change the settings on the phone and update the config, I get the failure `url too long'. In some earlier surches I found in bug <CSCsg22098> to upgrade to version 4.2(3)ES10. Is that the solution and how can I get it?
Thanks in advance.
Attached youll find a screen shot
Rob Huffman
Hall of Fame Community Legend Hall of Fame Community Legend
Hi Erich,
Just to add a note to the good tips from my friend Java (Happy Friday Java ...+5)
From the page the Java linked;
Go to;
Software Delivery System
Voice and Unified Communications is now available for download through the new delivery system.
To access Voice Software downloads, click here.
Voice and Unified Communications > IP Telephony > Call Control > Cisco Unified CallManager Version 4.2 > Unified Communications Manager Updates > 4.2(3)SR4b
Here are the Release Notes;
Cisco Unified CallManager 4.2(3) Service Release 4b
http://www.cisco.com/web/software/282074295/23506/ciscocm.4-2-3-sr4b-Readme.pdf
Hope this helps!
Rob
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
install the latest SR to fix this
java
if this helps, please rate
java
Thanks for the reply, but where to find this release? I checked the download DB of Cisco but didnt find!? In the past it something like ciscocm.4-2-3-sr1.exe for example.
Jaime Valencia
same place as always: download center
http://www.cisco.com/kobayashi/sw-center/sw-voice.shtml
java
java
Rob Huffman
Hi Erich,
Go to;
Hope this helps!
Rob
Recognize Your Peers
