Call Route Pattern issues
Sean Grubb
I am trying to create a new Route Pattern for a 511 service here in GA. It works fine with 411, so I essentially just copied the pattern from 411 and changed the number to 511. Nothing different, and yet it says "Call cannot be completed as dialed". I test 411 and it works fine, no issues. I call 511 on my cell phone and it connects so I know we have the service. Any ideas? We are using CUCMC System version: 7.1.5.33900-10. What else information would you guys need to be able to help me figure this out a little more?
Please, check if the "ComplexPSTN" Partition is placed inside the "Evans_DeviceCSS"
5 Replies 5
Pedro Francezi
Please, try to use the DNA tool and see if the call is being routed
Use the https://<CUCM-IP-ADDRESS>/dna and make an trace of the call.
Please, let me know the results.
Ok let's see what happens.
Okay I checked that and it was not. Just got done moving that around and it calls the 511 service! Thanks!
  • Results Summary
  • Calling Party Information
    • Calling Party = 7359
    • Partition =
    • Device CSS =
    • Line CSS = Evans_DeviceCSS
    • AAR Group Name =
    • AAR CSS =
  • Dialed Digits = 511
  • Match Result = RouteThisPattern
  • Matched Pattern Information
    • Pattern = 511
    • Partition = ComplexPSTN
    • Time Schedule =
  • Called Party Number = 511
  • Time Zone = Etc/GMT
  • End Device = Complex-PRI-RL
  • Call Classification = OffNet
  • InterDigit Timeout = NO
  • Device Override = Enabled
  • Outside Dial Tone = NO
  • Call Flow
  • TranslationPattern :Pattern=
    • Partition =
    • Positional Match List = 511
    • Calling Party Number = 7359
    • PreTransform Calling Party Number =
    • PreTransform Called Party Number =
    • Calling Party Transformations
      • External Phone Number Mask = NO
      • Calling Party Mask =
      • Prefix =
      • CallingLineId Presentation =
      • CallingName Presentation =
    • ConnectedParty Transformations
      • ConnectedLineId Presentation =
      • ConnectedName Presentation =
    • Called Party Transformations
      • Called Party Mask =
      • Discard Digits Instruction =
      • Prefix =
      • Called Number =
  • Route Pattern :Pattern= 511
    • DialPlan =
    • Route Filter
      • Filter Name =
      • Filter Clause =
    • Require Forced Authorization Code = No
    • Authorization Level = 0
    • Require Client Matter Code = No
    • PreTransform Calling Party Number = 7359
    • PreTransform Called Party Number = 511
      • External Phone Number Mask = YES
      • Prefix =
      • CallingLineId Presentation = Default
      • CallingName Presentation = Default
      • ConnectedLineId Presentation = Default
      • ConnectedName Presentation = Default
      • Discard Digits Instruction = None
      • Prefix =
      • Called Number = 511
  • Route List :Route List Name= Complex-PRI-RL
    • RouteGroup :RouteGroup Name= Complex-PRI-RG
        • External Phone Number Mask = Default
        • Prefix =
        • Discard Digits Instructions =
        • Prefix =
      • Device :Type= MGCPT1PRIPort
        • End Device Name = S0/SU2/DS1-0@ccrr1.columbia.gov
        • PortNumber = 0
        • Device Status = Registered
        • AAR Group Name =
        • AAR Calling Search Space = Evans_DeviceCSS
        • AAR Prefix Digits =
        • Calling Party Selection =
        • CallingLinePresentation =
        • ConnectedLinePresentation =
        • Number Of Strip Digits =
        • CallerID DN =
        • End Device Name = S0/SU2/DS1-1@ccrr1.columbia.gov
        • PortNumber = 0
        • AAR Group Name =
        • CallerID DN =
        • End Device Name = S0/SU0/DS1-0@wwar1.columbia.gov
        • PortNumber = 0
        • AAR Group Name =
        • CallerID DN =
        • End Device Name = S0/SU0/DS1-0@rrar1.columbia.gov
        • PortNumber = 0
        • AAR Group Name =
        • AAR Calling Search Space = RR_DeviceCSS
        • CallerID DN =
  • Alternate Matches
  • Note: Information Not Available
