Call transfert to subscriber greeting after Bulk import
j.bilodeau
Unity 4.0.3 and CCM 3.3.4
Every time I use CUBI to create subscribers, calls goes to subscribers greeting instead of the subscriber phone. Have to do a dummy change on the call transfert and then, it's ok. I did a dummy change on the template before also, but still got the same problem. Is this a bug or is there something I can do?
lindborg
looks like you're hitting this bug:
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCea14540&Submit=Search
although it claims to have been fixed in 4.0(3).
You could also be hitting this one:
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCec59720&Submit=Search
that one sounds a bit different but I think it will have the same effect you're seeing here. This one was fixed in 4.0(4).
