Showing results forĀ
Search instead forĀ
Did you mean:Ā
Call Volume for FAX Lines in CDR REPORTING
davidgray40
Level 5
Level 5
Does anyone know if there is a way to capture the Call Volume for FAX lines that are in Analog (VG204) Gateways and In 2921 Gateways via the CDR Reporting tool in CUCM 10.5?
I need like a 30 day window for each Fax number at various locations and various gateways.
0 Replies 0
