02-25-2014 01:06 PM - edited 03-19-2019 07:57 AM
Hi!,
I Have a CUCM with the 9.1.2 version and im having an issue with the information of the CDR... I have a billing application called Billy Blues 4 working and when I execute a report of an especific user of the "calls of the day" the information that the application shows do not match with the real number of calls made by the user... I download the complete CDR of that day and the information is the same of the billing application but not all the calls are being registered....
any idea that why is happening this???
Solved! Go to Solution.
02-26-2014 08:30 AM
So it was not enabled, as you intially said it was??
Because I couldn't find an explanation for calls not being logged, other than failure to enable CDR on all servers.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
02-25-2014 01:45 PM
Do you have CDR enabled in all servers??
java
02-25-2014 01:50 PM
Yep, it is enabled in the publisher server and the 4 subscribers
02-26-2014 08:25 AM
Solved... I miss that this flag in the picture (CDR Enabled Flag) was only enabled in the publisher but this parameter do not reply in the subscribers... i mannualy enabled on each server and work...
02-26-2014 08:30 AM
java
02-26-2014 08:34 AM
yeah, my mistake...
