CDR Raw DB integration
Bhavani Sankar
Hi All,
Greetings....
We have CUCM 11.X cluster. We configured to send CDR reports as schedule for daily, monthly. For monthly detailed report, we are getting the detailed report for only 3 days as the data is huge. Is there any way to retrieve the data/ integrate the DB to some other server and retrieve the same.
Thank you in advance.
Sankar.
Gordon Ross
Level 9
Level 9
CUCM can FTP/SFTP the CDRs (as they're generated) to another server. From there, you can import them in a database to do your own querying (or buy a third party product to do the same)
You can define up to three CDR SFTP/FTP destinations.
Look in https://<CUCMPUBLISHER>/ccmservice -> Tools -> CDR Management
GTG
Please rate all helpful posts.
