CDR Record in SIP Trunk
warquezho0612
I have this setup where our local telco provider connects to us via SIP trunk. Now I am wondering if it is possible to get the calls logs of CDR in this SIP Trunk? Because whenever I go to CDR, only the H.323 ip address is the available option.
Best Regards,
Makoy
Gordon Ross
Level 9
Level 9
CDRs on CallManager record all calls, irrespective of device or protocol, so I'm a bit surprised that your CDRs are missing one particular type of call.
GTG
Please rate all helpful posts.
I find it kind of weird as well, although I have not experience viewing CDR when SIP is the protocol since all of my gateway are either h323 or mgcp.
So what do you think I am missing?
I am also having this issue with 10.5 CUCM version. MGCP and H323 are working fine, but SIP gateways don't. I thought it was a gateway problem but I did review the configuration under 10.0 and 9.1.2 version and it works. My gateways are 3 CUBEs and 2 SIP connecting E1/PRI.
