Centralized Presence and SSO
crahill41
I am working on a scenario with Centralized Presence and Jabber SSO. SSO integration is with ADFS 2.0 on Server 2016. The topology is:
Core Cluster - 1 CUCM and 1 IMP server (Version 15) acting as the Centralized IMP Cluster
SME Cluster - 1 Hub, 2 Spokes
SSO Integration was successful on all nodes using Cluster Wide certs and Tomcat (Internal signed on the Server 2016 server.). Login to CCMUser pages works using SSO, but Jabber login fails - service discovery works through ILS and Jabber client receives an Pop up window from the ADFS server to login, and the credentials never work.  If I remove SSO, Centralized Presence works fine.
Not sure where to start on this one. Any suggestions would be greatly appreciated.
Craig
crahill41
Found the issue. It was a default setting inside of ADFS. Unchecked the Windows Authentication box and everything started working correctly.
crahill41
