07-20-2016 08:12 AM - edited 03-19-2019 11:22 AM
There is no PLM specific documentation on changing the IP address on a Prime License Manager server.
What procedure should be used and do licenses need to be rehosted or licensed instances removed and re-added?
Thanks!
Solved! Go to Solution.
07-20-2016 08:39 AM
Hi Kevin,
check the link below.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/plm/11_0_1/userguide/CPLM_BK_U2C0C808_00_user-guide-rel-1101/installation_1101.html
Hostname |
Enter a hostname that is unique to your server. The hostname can comprise up to 32 characters and can contain alphanumeric characters and hyphens. The first character cannot be a hyphen. |
Yes, you can change the entry after installation. set network hostname
IP Mask |
Enter the IP subnet mask of this machine. |
Yes, you can change the entry after installation by using the following CLI command: set network ip eth0 |
Also keep below in mind.
https://supportforums.cisco.com/discussion/12331101/prime-license-manager-ip-address-change
JB
07-20-2016 08:39 AM
Hi Kevin,
Hostname |
IP Mask |
JB
07-20-2016 08:53 AM
Thanks, Jitender :)
07-20-2016 08:55 AM
Happy to help.
JB
