11-05-2012 12:45 AM - edited 03-19-2019 05:49 AM
I have CUCM 8.6 and combination of 7900 and 3900 phones in my VOIP network, recently i have started facing issue with 3905 phones, they are resetting automatically and says Registering.
I just wanted to know what logs i need to collect from RTMT to identify the reason for this issue.
MAC
11-05-2012 01:58 AM
Check you network as these issues are generally caused by loss of connectivity.
01-24-2013 02:01 AM
I've the same issue, do you have any updates regarding these case ?
Stefan
01-24-2013 08:22 AM
Hello Stefan,
Whats the firmware version of the 3905?
Leonardo Santana
01-24-2013 10:41 AM
Hello Leonardo,
Tranks for reply!
Fw is 9.2.2.0
01-24-2013 10:43 AM
Hello Leonardo,
Thanks for reply!
FW is 9.2.2.0
BR
/Stefan
01-24-2013 10:45 AM
And when they reboots after an call?
Only this IP Phone model have this issue?
Leonardo Santana
01-24-2013 11:47 AM
The phones reboots up for 50-60 per Day.
If I take a look in the CUCM the phone ist registered,
But the issue is facing only the 3905 phones. All other phones working fine.
Do you have an idea how I can troubleshoot These issue ?
BR
/Stefan
01-24-2013 11:57 AM
From RTMT can you see the reason code of the phones there are rebooting?
Or you can connect via CLI:
Event Viewer-Application Log
File get activelog syslog/CiscoSyslog*.*
File get activelog syslog/AlternateSyslog*.*
Event Viewer-System Log
File get activelog syslog/messages
And access the IP Phone messages status to see whats happens:
http://IP Phone IP/Status_Messages.html
Leonardo Santana
01-31-2013 04:50 AM
Hi Lenardo,
How do we check the reason code using RTMT? i think we can get the route cause if we get reason code.
MAC
02-01-2013 04:11 AM
If i not wrong goes to RTMT->Tools->Syslog Viwer-> Application Logs-> Cisco SysLogs
Leonardo Santana
05-28-2013 08:01 AM
Hi Leonardo,
I have attached the logs from RTMT->Cisco SysLogs
Please check and suggest me to find the Reason Code
MAC
05-28-2013 08:04 AM
09-16-2013 07:27 AM
Hi Mohamed;
I have the same problem, Do you have any solution for it?
Regards;
Fabio
09-16-2013 11:59 AM
I have the same issue, only with the 3905 phones. The phones register fine but after 2 minutes tries to re register and they fail, so the phones resets and then register again.
I can call or receive calls fine while the phone is registered.
Any advice?
