Cisco ASA Phone Proxy and call recording using BiB
a.leahy
Beginner
Beginner
Hi all
Are there any issues with this? I've not managed to find a link that states it's ok or not but I have found a couple of forum discussions where CR has been disabled to get things working....
Andy
7 Replies 7
skilambi
Advisor
Advisor
Hi Srini
That was quick
Have you got anything a bit more definite? I don't think that's an answer I can put before a customer.....
Andy
Yeah I wish, that is from the PM for Calabrio so I don't think it can get any more definitive , basically try it but if it doesn't work...well you have to use a supported configuration
Srini
Hi Srini
Are you saying this not a supported solution?
Andy
That's how I interpret the post...it should work but is not a documented supported use case and it hasn't been tested
Srini
Cool - thanks, you are a star Srini (again!)
No problem, glad to help.
Srini
Recognize Your Peers
