cisco be6000 multi tendant
carlos_nana
Gi,
my name is Carlos and I want deploy telephony as a service , telepresence as a service  ....
I'm not sure if BE6000 can be use and deploy with multi tenant mode.
Thanks for your feedback
Jaime Valencia
Yes, just as any other CUCM deployment, and as long as you stay within the limits of a 6K solution.
java
if this helps, please rate
