11-24-2014 03:14 AM - edited 03-19-2019 08:52 AM
We're developing a program that contacts the Cisco Conductor (2.3) via API.
We have created an user API on Concuctor enabled & active.
When I try to use this account to contact the Conductor we receive the following error "Fault 201: Request received from unknown IP address. Factory Request IP 127.0.0.1 Factory source IP 10.14.50.111".
IP 10.14.50.111 is the CPU that manage the API connection.
Fabio
11-24-2014 05:39 AM
Hi Fabio,
Check the firewall rules maybe and more pricesely the user-configured rules :
The user-configured rules are typically used to restrict what can access the TelePresence Conductor. You can:
- Specify the source IP address subnet from which to allow or deny traffic.
- Choose whether to drop or reject denied traffic.
- Configure well known services such as SSH, HTTP/HTTPS or specify customized rules based on transport protocols and port ranges.
- Specify the priority order in which the rules are applied.
Hope that helps!
11-24-2014 06:08 AM
Thanks for feedback.
Firewall is disabled.
We've also tried to enable it but nothing has changed.
Fabio
