Cisco CUBE - SIP Provider Inbound Call issue
Remon.BA
Dears
This is new deployment for integration between
CUCM 11.5 - CUBE (2911) ----SIP Provider
Inbound and outbound calls fail , but lets focus first on inbound .
As appeared CUBE sending 180 Ringing messages to SIP Provider without any response , i have shared these logs with Provider but no valued  feedback from their side
Attached logs for inbound call test and sh run
Attached : debug ccsip messages
Regarding CUCM Settings
On SIP Trunk : MTP Enabled
Early offer coded g711alaw
and below is SIP Profile settings
Vaijanath Sonvane
Hi @Remon.BA,
From the logs, the SIP call flow appears to be progressing normally. You will only see  200 OK followed by an ACK once the call is answered by Phone registered on CUCM.
  • Is the phone on CUCM not ringing?
  • Are you not getting ringing tone on callers phone?
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Could you ensure the call lands on the phone? From the logs I expect the call to ring on the phone .
If the call rings and you answer it by picking up the desk phone, since we don't see a 200 OK, I assume that CUCM didn't recognize the call was answered, causing it not to send the 200 OK to the gateway and the ITSP.
Is there a firewall between the CUCM and the IP phone? If yes, make sure you disable SIP inspection.
Your gateway configuration needs a lot of fine-tuning as it deviates significantly from best practices
Response Signature
