04-24-2025 05:22 AM
I need to setup two dial-peer with SIP trunks that need to point to 15 SBC with failover.
Does anyone have a sample configure with dil-peer with SIP trunks pointing an srv record will all the servers listed.
thanks
Solved! Go to Solution.
04-26-2025 10:32 AM
Have you looked at this chapter in this document? Configure and Troubleshoot DNS Resolution
04-24-2025 01:35 PM
Not sure what you mean by “pointing an srv record will all the servers listed”? Can you please elaborate? The SRV record is setup in the DNS server and your just referring to it on the dial peer.
04-26-2025 02:20 AM
that what I ment to say. looking for the right config that will hit the dns server which is point to a srv record
04-26-2025 10:32 AM
