06-02-2015 11:34 PM - last edited on 03-25-2019 09:54 PM by ciscomoderator
Hi team,
Recently we have purchase one BE6K - UCS Server. my requirement is Cisco JABBER Installation document and requirement for ports & Protocols details(Windows & Mobiles). need jabber Features presentation document. Kindly Share the any presentation & Installation document.
regards,
Johnson.
06-03-2015 04:16 AM
The jabber documentation is available on cisco.com if you simply search for it...
cisco.com -> Support -> All Products
Then either:
a) use the decision tree to look for the product
b) click the "Select a Product" drop down, scroll for the product, or type in the name of the product
If you require slides on the product, reach your SE.
06-04-2015 12:30 AM
Hi Sir,
Thanks for your Reply,
I have one query, we have planing to CUCM upgrade, present running CUCM 8.0.3 with MCS server, now we are planing P2V ( MCS to UCS) from version 8.x to 10.x. and install the presence server also. my question,need to usage guidelines of Jabber within the campus and remotely , Bandwidth consumption when accessed through WiFi solution
we have DLU license,same license file to migrate to 10.x. need any additional license is require for Jabber mobile & Desktop clients?
pls help on this...
Thanks & regards,
Johnson.
06-04-2015 06:09 AM
You'll need to get your benchmark data as you roll out Jabber, that is not something we have as it completely depends on your particular scenario, services, number of contacts, etc.
As to the license questions, go to pre-sales for that.
