Cisco Unity Connection attendant not transferring call
Ronit Malhotra
Cisco Unity Connection 7, for one user when dialing by name in the auto attendant it is sending call directly to voice mail, not to extension
Secondly we want if we search user is directry call handley it should go to asssistant extension
Jaime Valencia
Look at the transfer options for that particular user and make sure it's set to ring the phone, that configuration is PER user.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
