Cisco UP XCP Router Service not running
Jose Arango
I installed presence  8.0.0.39051-20 server, it is integrated with the CUCM 8, but the UP XCP Router Service nerver start, I started Manually but it puts in Not running State again.
Where could be the problem??? i read that this service start by default.
5 Replies 5
mdawar
Hi Jose
Check the SIP proxy domain value in the "SIP Proxy" service Parameters.
Confirm that it is set to correct value and reset the Cisco UP Presence Engine service.
Hope it helps.
I did it, but it does not work
Hi Jose,
The version looks wrong ? As far as I know there is no CUP version 8.0.0.39051-20
Can you doublecheck that ?
Christos
Nathan Compton
Level 4
Level 4
I'm having a similar issue in the lab.  Were you able to resove it?
Adam Compton
Hello, i reinstalled and applied the 8.0.2 patch, now it´s working.
