04-20-2015 04:22 PM - edited 03-19-2019 09:29 AM
On Cisco Unified CM IM and Presence Administration 10.5.2.20000-1 the Cisco XCP XMPP Federation Connection Manager service will just stop running and I must go in at least once every two weeks to restart the service. Has anyone heard of this happening or know of the fix? Thank you.
04-20-2015 11:08 PM
You can check if there are any cores being generated on the server by running the following command
utils core active list
Also, it looks related to the following bug which was recently opened for similar issue ( although the service restarts automatically in this case )
https://tools.cisco.com/bugsearch/bug/CSCus82938/?reffering_site=dumpcr
You may need to engage TAC for further analysis.
Manish
04-21-2015 02:50 PM
Thank you Manish. I will try your suggestions.
04-21-2015 06:51 PM
Are you actually running something that requires federation, ie a connection with MSFT or something similar?
