CLI removal of Domains
garethpeart
Level 3
Level 3
I was wondering if anyone has successfully removed a domain through the CLI? I have a domain that refuses to be removed in the Web page (claims to be successfully removed but still shows) and want to see if I can remove it another way.
Gareth
Anthony Gerbic
Gareth,
PCP supports removing a domain by only two ways: Web UI and Batch. There is no specific CLI to do it. If the UI has some issue, you could try using the batch. The sample patch file for removing domain can be found in the batch sample directory on PCP server, or downloaded from the Batch UI starting in PCP 11.0.
By the way, if the UI has issue, open a TAC case so we can gather info to fix this. It should always work from the UI.
Thanks Anthony,
I ended up deleting the VM and Setting up a new VM with the latest version of pcp (11.0)
Gareth
