11-22-2016 04:39 PM - edited 03-19-2019 11:51 AM
Dose any boby knows if exist a compatibility to mount a B6K (Virtual appliance) in a Hyperflex HX240
Best regards
11-22-2016 05:02 PM
You can refer the following doc for compatibility info:
http://docwiki.cisco.com/wiki/UC_Virtualization_Supported_Hardware#.22Can_I_use_this_server.3F.22
Please rate and mark correct if helpful.
Hitesh
11-22-2016 05:59 PM
The answer to your exact question, is NO.
A BE 6K in any size, can only be considered as such, when it's running on one of the 6K platforms from the link Hitesh provided.
If you choose to change ANY of the HW components from the BOM from such options, or the RAID, then it's no longer a 6K, it will turn into specs based UC on UCS, and you lose the TRC level of support.
So, can you run a 6K on hyperflex?? NO
Can you run UC products on hyperflex?? YES
It will be considered as running specs based UCS
03-04-2018 09:55 PM
Hello Israel,
Compatibility UC B6k with Hyperflex HX240
Please refer the link below.
