04-20-2018 09:23 AM - edited 03-19-2019 01:18 PM
Hello All,
IM and Presence: 10.5(2)
CUCM: 10.5(2)
Jabber: 12.0
Is there a way to configure locations in IM and Presence, where you can pre-configure locations for Jabber clients.
It looks like from a few things I read that location is discovered by using the MAC Address of the connected Gateway (*or with a combination of MAC and Subnet). So is there anyway on the Server side to pre-configure these locations so the Jabber clients get the location from the Server automatically, instead of manually having to enter it?
Thanks in Advance,
Matt
Solved! Go to Solution.
04-20-2018 09:39 AM
No, there is no way to do that
http://docwiki.cisco.com/wiki/Jabber_FAQ#Can_I_pre-configure_the_locations_in_version_10.6.2B.3F.3F
04-20-2018 09:39 AM
04-20-2018 09:41 AM
04-20-2018 09:44 AM
Did you look at the status of that request?
04-20-2018 09:48 AM
04-20-2018 09:51 AM
Correct, it was investigated at some point in time, but since it was terminated, that means the product team decided not to look further into it.
04-20-2018 09:53 AM
