Connect BE6000 to Two Analog Line from PSTN
ajmal1
I have Implemented Cisco BE6000 for one of the customers which we agreed to connect to PSTN through E1 Trunk Line. But due to Budget issue, they request two Analog Line from PSTN and they need to allow Employee to received a call from outside and Do a call also to outside.
so there is an analog card can be installed on the BE6000 to allow the connection and how to configure it?
I have BE6000 version 11.5
total no of Extension 50 IP Phones.
Please advise.
Jaime Valencia
BE 6000 M/H run on UCS servers, you cannot install any TDM cards on it.
You need an ISR for what you need, and then integrate it with CUCM with the protocol you want to use.
java
if this helps, please rate
