Conversation options in Unity Connection
melvin.fong
Is there a document that tells what the options are when you log into your mailbox?
I am trying to get together a doc for users now using Unity 5.0 and we are moving to Unity Connection 8.5.
Thanks is advance....
Anthony Holloway
Gvie this tool a shot, and tell me if it can provide what you are looking for:
http://www.ciscounitytools.com/Applications/CxN/WalletCardWizard/WalletCardWizard.html
Thanks!
looks like a great tool! Need to setup conn and give it a try....
Rob Huffman
Hi Melvin,
Just to add a note to the good tips from Anthony (+5"A")
If you are using the "Standard Conversation" in both versions, the user experience
should be nearly identical
For Unity;
Phone Menus for the Standard Conversation
http://www.ciscosystemsverified.biz/en/US/docs/voice_ip_comm/unity/405/user/guide/exum/405um165.pdf
For Unity Connection;
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/user/guide/phone/8xcucugphone_chapter21.html#reference_E5D5049FD5C34F93AE421A1836EF0CC2
Cheers!
Rob
