CUBE and SIP profiles header manipulation
MrMartin
Hi there!
Im trying to figure out how to use sip-profiles in CUBE to modify a SIP invite header. So for example when i call sip:12345@someip i would like the CUBE to modify it to alphanumeric SIP:martin@someip and route that out to a specific dial-peer.
Is this possible and how can i achieve this ?
I have configured as below, but that is not working.
thanks for any help! BR Martin
voice class uri martin sip
user-id martin
voice class sip-profiles 1
rule 1 request INVITE sip-header To modify "(<.*:)(.*@)" "\1martin@"
rule 2 request INVITE sip-header From modify "(<.*:)(.*@)" "\1martin@"
CUBE1#sh run dial-peer
Current configuration:
dial-peer voice 101 voip
description Incoming Calls from PBX
session protocol sipv2
incoming called-number .
voice-class sip profiles 1 inbound
voice-class sip bind control source-interface GigabitEthernet1.10
voice-class sip bind media source-interface GigabitEthernet1.10
codec transparent
no vad
dial-peer voice 102 voip
description Incoming Calls from Second CUBE
voice-class sip bind control source-interface GigabitEthernet2
voice-class sip bind media source-interface GigabitEthernet2
codec transparent
no vad
dial-peer voice 201 voip
description Outbound to PBX
destination-pattern ......
session target ipv4:10.10.10.97
codec transparent
no vad
dial-peer voice 202 voip
description Outbound to Second CUBE
session target ipv4:10.20.20.2
destination uri martin
codec transparent
no vad
end
Have you turned on use of inbound SIP profile globally?
voice service voip
 sip
  sip-profiles inbound
This document is one of the most linked to when it comes to IOS call routing. Explain Cisco IOS and IOS XE Call Routing
I would suggest that you'd do some changes to you dial peers as they are somewhat not optimally crafted.
voice class uri PBX sip
 host ipv4:<IP of PBX as sent in VIA header>
 host ipv4:<add more lines as needed up to the maximum of 10>
voice class uri CUBE sip
 host ipv4:<IP of CUBE as sent in VIA header>
 no incoming called-number .
 incoming uri via PBX !Uses information in VIA header to match inbound dial peer
 incoming uri via CUBE !Uses information in VIA header to match inbound dial peer
 destination-pattern <change this to something that is more specific than destination-pattern ...... as that maches any 6 digits>
 no destination-pattern ..... !As you're intending to match on information in the destination uri this is redundant
Response Signature
MrMartin
Thanks! i will have a look at this.
I also found this tools very helpful https://cway.cisco.com/csa-new/#/sipprofiletest.
Best regards Martin
