CUBE HA with PRI TDM port
Tony_S
Need CUBE HA but a PRI as well, how do the HA solutions compare (box to box and hsrp). Is PRI supported or better suitable in either ? I do have the option of relocating a pair of 2x3900 and doing hsrp, or go for an new pair of 4400.
Jaime Valencia
CUBE HA is not supported with TDM/analog.
You would need a pair of ISRs for CUBE HA, and another ISR for TDM.
java
if this helps, please rate
Jaime Valencia
java
