Cube QoS
scooter817
Level 2
Level 2
Hi Everyone
I wanted to know can you someone point me in the right direction to  some documentation that will show me how to configure Qos for a Cube router. The reason I ask it becuase I have a location in NYC that everytime they try to transfer a call the call drops. The guy who's place I took opend up a case with TAC and the TAC engineer said " As previously stated on my previous email, the running-config suggests that there is no QoS service-policy applied to any interface; hence, the router is not applying any kind of priority queuing and will treat the packets on a FIFO (First In First Out) fashion. However, I would like to get a show tech-support output from the router in question for me to get a better look at the overall setup for this router as well as its interfaces". I just sent the TAC engineer the info that he requested. I don't know if TAC wil help with configuring QoS but if they don't what is the easiest way to configure QoS on the interfaces. Thanks in advance for the help and I look forward to your replies.
Eric
Manish Gogna
Hi Eric,
If you are looking for a sample QOS configuration on CUBE for voice traffic here is a general configuration:
class-map match-any rtp
match ip rtp 16384 16383
class-map match-any voice-control
match dscp cs3 af31
match protocol mgcp
match protocol h323
match protocol sip
match protocol skinny
policy-map voice-qos
class rtp
priority <bandwidth>
set dscp ef
class voice-control
bandwidth <bandwidth>
set dscp <whatever the provider wants to see for signaling, use 0 if unknown or if no queue is provisioned for signaling>
class class-default
fair-queue
random-detect dscp-based
set dscp 0
policy-map shaper
class class-default
shape average <upload speed of circuit>
service-policy voice-qos
interface <int>
service-policy output shaper
You can check the CUBE config guides for more details.
Manish
Manish Gogna
Hi Eric,
match dscp cs3 af31
match protocol mgcp
match protocol h323
match protocol sip
class rtp
set dscp ef
class voice-control
class class-default
fair-queue
set dscp 0
policy-map shaper
class class-default
interface <int>
Manish
