CUCM 10.5 with EsXI 6.5
I have a CUCM and CUXX 10.5 installed on EsXi 5.1 on a UCSC220-M3SBE.
Can I upgrade to ESXi 6.5 and still using the same CUCM/CUXX version?
@Unified Comms Guy
Thanks a lot!
Chris Deren
Chris Deren
Yes, CUCM 10.5 is compatible with ESXi 6.5, refer to follow matrix:
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/virtualization-cisco-unified-communications-manager.html#v10.5
Not sure what CUXX stands for, are you referring to Unity Connection (CUC or UCXN) or Contact Center Express (UCCX)?  In either case CUC compatibility is here:
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/virtualization-cisco-unity-connection.html#v10.5 (same as CUCM)
and UCCX:
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/virtualization-cisco-unified-contact-center-express.html#10
which does not support ESXI 6.5
