CUCM 9.2 Block spam incoming calls from specific number
Aaron Alvarado
Team,
 what is the best way to block spam incoming calls from a specific number?  I am looking for the easiest way but I am not sure if can be done from CUCM 9.2 or the directly at the voice gateway.
Jaime Valencia
How to block calls on CUCM or ISRs has been discussed many times here, did you look at any of the previous threads on the topic?
java
if this helps, please rate
