01-25-2014 01:03 AM - edited 03-19-2019 07:48 AM
Hi community.
I'm looking for a 64 bit Tapi driver to connect to CUCM. From which CUCM version on does cisco provide a 64 bit Tapi driver?
And is it possible to uninstall an upgrade from version 9.1 back to 8.0?
Thanks for your support. Patrick
01-28-2014 11:27 AM
I believe CUCM 8.5.1 introduces the 64 bit TSP and is included in every version onward. What version did you upgrade from? Depending on that, you could simply do a switch version back to the old version sitting on the inactive partition. Please keep in mind that if you do revert back to an older version, you must reset database replication.
Tony
Please rate helpful posts!
01-29-2014 06:47 AM
Hi Tony.
I'm Upgrading from 8.0.3.20000 to 9.1. Is it possible to do a switch version back to the old version sitting on the inactive partition.
thanks patrick
01-29-2014 06:57 AM
Yes you can. After upgrading to 9.1 you will be able to do a switch version back to the inactive partition that is housing your previous version 8.0.3. Again, if you do revert back to 8.0 you will have to reset database replication.
Tony
